Carb troubles
Old Jul 10, 2001 | 03:03 PM
epithelium's Avatar
When I start my quad the motor revs very high and you can't shut it off by hitting the switch from run to stop but when I open the choke it idles normal. WHat could be my problem.[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Jul 10, 2001 | 03:29 PM
HyperSport400XC's Avatar
It sounds like you have a lean condition on the idle circut. The best thing to do would be to take the quad to a dealer if you are unfamilier with the internal workings of a carb. Perhaps the pilot jet is plugged. What machine is it on.
Old Jul 10, 2001 | 03:32 PM
epithelium's Avatar
96 trailblazer just rebuilt top end head work removed starter and oil injector.
Old Jul 10, 2001 | 04:09 PM
Crawdad's Avatar
You may have an air leak somewhere causing a super lean condition....that's not good on a newly rebuilt top end. Or it could just be a throttle cable not returning to the idle position.
Old Jul 11, 2001 | 07:31 AM
I'm inclined to agree with Crawdad on this. Check the cylinder base gasket, your oil injection plug and the manifold where the carb boot meets the cylinder head. Some where you are getting a leak. To detect it, try CAREFULLY spraying starter fluid around the base gasket, the plug for the oil injection and the manifold. If the idle calms down, that is the spot where it is leaking.
Old Jul 11, 2001 | 08:06 AM
Balzak's Avatar
I don't know if this will help you but when I was having my burned up piston problem I stripped the bike of the plastic in the woods and started to work on it. When all of a sudden it fired and then started to rev through the roof, the problem was that I didn't have the plug from the front part of the plastic plugged into the wiring harness (you have to undo it to get all of the plastic off). There was no way to shut it down at all the switches won't work so all I could do was pull the plug wire to get it to stop. I still don't know why it did it but it never has done it since. Of course I did have to change the piston and rings.
Balzak
2000 scrambler 400 2x4
HPD this and that and more this and that
Old Jul 11, 2001 | 09:15 AM
epithelium's Avatar
balzak which plug are you referring to I think this may be my problem.
Old Jul 11, 2001 | 02:17 PM
Balzak's Avatar
The only way to get it to stop was to pull the spark plug wire off the plug or if you can handle it reving like crazy for a while you can just unconnect the gas line. Once I hooked the connector up to the instrument panel I was then able to shut it off again. I just propped the plastic up enough to connect the plug and then I could work on it without incident.
Balzak
2-strokes for fast folks
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
Dirtbikemike1
Jul 21, 2015 04:13 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
