Lakota carb.
Old Jul 17, 2001 | 11:31 PM
bigbadlakota's Avatar
I have a Lakota and i was wondering if you guys could tell me where the air and fuel mixture screw is because it's running way to rich.
Old Jul 18, 2001 | 12:54 AM
stebob's Avatar
On the very bottom of the carb. facing straight down. It is a flat head screw. It's easiest with a 90 degree angle driver. You may want to loosen the carb. and rotate it a little so you can see better. You won't miss it.
Old Jul 18, 2001 | 01:07 AM
Wich way do you turn it if it is running to rich. If you sittingon the quad do you turn it right or left. Thanks for the help.
Old Jul 18, 2001 | 01:14 AM
stebob's Avatar
Here's the way Dyno Jet told me how to do it. SuperTrap agreed. Loosen the screw counter clockwise until the machine starts to run poorly. Back off until smooths out. Check the plug again after running it. This method worked well for me. Hopefully someone will post if there is something I'm missing.
wendal
Oct 31, 2017 03:31 AM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Sassinm1
Sep 30, 2015 04:23 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
