Blaster stalling and no power......
Old Jul 26, 2001 | 06:19 PM
RdingManiac420's Avatar
I took my Blaster down my drive to get the mail. I got to the bottum shut it off and got the mail. I stared it back up and it wouldnt rev up it just popped and sputter and boged. I would try to go and it would just stall cause I couldnt rev it at all.It sometimes does this if I ride for a long time and then blast through a mud hole. And usually after letting her sit she'll start back up. But today I didnt go through any mud and it wont start again. The past couple weeks the only way it would start is if I held the throttle wide open and kicked it even when hot.What is wrong with this thing?? I can sell it if it doesnt run.
Old Jul 26, 2001 | 08:55 PM
peterbilt's Avatar
well before you go and sell the thing you should at least check out a few things first, clean the air filter, clean-up the carb real good and check your jetting,if it improves a bit but not all the way than you probley need to rejet if you don't see any improvement at all after cleaning and tuning the carb than I would check the flywheel key cause it might be partialy sheered.
well good luck
Old Jul 27, 2001 | 03:16 AM
bLaStEr1435's Avatar
Try a new plug. Most of the time when I have problems I first try a new plug and that ussually takes care of it.
1995 yamaha blaster, k&n filter, paul turner pipe, 14 tooth front sprocket, oil injection block off, graydon skid plate, and rear holeshot tires
Old Jul 27, 2001 | 10:49 AM
madweazl's Avatar
While you have your plug out check your compression. Hopefully its just the plug but it also sounds like you have low compression.
Old Jul 27, 2001 | 01:07 PM
peterbilt's Avatar
yeah definatly check the plug and compression, I must have spaced it on that while writting my first response, sorry, I figured that you already checked out the plug so if you didn't, start there cause it is the most logical!
Old Jul 27, 2001 | 02:46 PM
Ok will do today. I sure hope I have good compression cause I have a very fresh top end. I think, hope it's just a fouled plug.
Pehter
Oct 3, 2024 11:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
nastyblaster100
Sep 13, 2015 01:19 PM
