400ex hub bolts and nuts are stripped
I read the other message about how to take off a nut stripped, and i can get them off. But my real question is, is can i replace those 4 bolts and nuts, or do i have to buy a whole new hub. Hopefully, i can just get those other bolts out and replace them. And then also, how would i go about getting them.
Derek
Derek
If you are talking about the four stud where you bolt the wheels on, you have a simple task in hand. First of all order the new studs and lugs from Honda. You can also look on powersportspro.com. They have a parts fish that has stock parts.
Now to remove the old studs. If the nut is stuck on the stud, go ahead and cut the old stud with a dremel or other means. Take a hammer and tap out the old stud. When the new ones come in replace in the reverse order.
Good Luck
Good Luck
i just tapped out the studs from my hubs with a hammer. show patience, don't try to get them out in 2 hits...anyway...here is the most important part: the honda shop will tell you that you have to order the whole hubs...don't do it...the wheel studs are part # 90103-ha2-003
the lug nut part numbers are 90314-vmo-771. the studs will cost around $5 each and lug nut not real sure.. i only needed the studs.
rest of you write down those part numbers if you have a 250r,400ex,300ex,250x and stick them around somewhere you will be able to find them if ever need...the 2 honda shops in richmond and several after-market companies tried to get me to by the whole hubs.
dirtclog
dirtclog
Well, I went to the dealership on tuesday, and yes, i did order them. Hopefully they will come in today (friday) In the mean time, i havnt really worked on getting the old, stripped ones out of there. I have mostly just been cleaning it up, and boy, is it clean. I finally put all my stickers on it, took all of my tires off and cleaned up them up, tire shined them, and even went as far as to go get a white tire marker and color the "Pure Sports Realtor" part of my tire in. Took my a-arms off and painted them, painted all of the hubs, and also the exhaust shield.
So basically, as soon as i pick them up, i will have them on in about an hour.
Oh and lastly, they did try and sell me a whole hub. Without that part number i would have been screwed, so thank you very much dirt.
