400ex hub bolts and nuts are stripped
Old Jul 30, 2001 | 10:25 AM
derekhonda's Avatar
I read the other message about how to take off a nut stripped, and i can get them off. But my real question is, is can i replace those 4 bolts and nuts, or do i have to buy a whole new hub. Hopefully, i can just get those other bolts out and replace them. And then also, how would i go about getting them.
Derek
Old Jul 30, 2001 | 12:01 PM
FOURWHLS's Avatar
If you are talking about the four stud where you bolt the wheels on, you have a simple task in hand. First of all order the new studs and lugs from Honda. You can also look on powersportspro.com. They have a parts fish that has stock parts.
Now to remove the old studs. If the nut is stuck on the stud, go ahead and cut the old stud with a dremel or other means. Take a hammer and tap out the old stud. When the new ones come in replace in the reverse order.
Good Luck
Old Jul 30, 2001 | 11:06 PM
derekhonda's Avatar
Thats what i wanted to hear, thanks. What do you mean in reversee order though?
Derek
Old Jul 30, 2001 | 11:36 PM
dirtclog's Avatar
i just tapped out the studs from my hubs with a hammer. show patience, don't try to get them out in 2 hits...anyway...here is the most important part: the honda shop will tell you that you have to order the whole hubs...don't do it...the wheel studs are part # 90103-ha2-003
the lug nut part numbers are 90314-vmo-771. the studs will cost around $5 each and lug nut not real sure.. i only needed the studs.
rest of you write down those part numbers if you have a 250r,400ex,300ex,250x and stick them around somewhere you will be able to find them if ever need...the 2 honda shops in richmond and several after-market companies tried to get me to by the whole hubs.
dirtclog
Old Jul 31, 2001 | 09:13 AM
derekhonda's Avatar
Thank you so much dirt, im on my way to the dealer right now, we will see if they try to pass one over me.
Derek
Old Aug 2, 2001 | 07:37 PM
dirtclog's Avatar
so did you get the 400ex fixed? i'm curious if you got what you neded from the dealer
Old Aug 3, 2001 | 09:41 AM
derekhonda's Avatar
Well, I went to the dealership on tuesday, and yes, i did order them. Hopefully they will come in today (friday) In the mean time, i havnt really worked on getting the old, stripped ones out of there. I have mostly just been cleaning it up, and boy, is it clean. I finally put all my stickers on it, took all of my tires off and cleaned up them up, tire shined them, and even went as far as to go get a white tire marker and color the "Pure Sports Realtor" part of my tire in. Took my a-arms off and painted them, painted all of the hubs, and also the exhaust shield.
So basically, as soon as i pick them up, i will have them on in about an hour.
Oh and lastly, they did try and sell me a whole hub. Without that part number i would have been screwed, so thank you very much dirt.
Joe454
Nov 20, 2020 01:19 PM
tysonbully
Sep 28, 2015 02:30 AM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
