three wheel drive scram help!
Old Aug 2, 2001 | 01:20 AM
scram5004x4's Avatar
when im fourwheeldrive only three tires pull
the left tire pulls sometimes and when driving
in twowheeldrive left tire sometimes locks up
please help! need to fix so i can ordr four paddels
Old Aug 2, 2001 | 02:14 AM
bmxatv10's Avatar
Sounds like your hub is not locking in, it may be shot, but not sure here let some other guys help you out here !!!!
Old Aug 2, 2001 | 09:19 AM
HyperSport400XC's Avatar
Scram 500 4x4,
Check the wires from the hub and trace them backwards. More than likely they are either disconnected or have a short in them.
Old Aug 2, 2001 | 02:31 PM
KevinM's Avatar
If its not a wiring problem, your magnetic coil may be going bad. You can check this by disassembling the hub. There is a thin plate that goes on the back of the roll cage assembly and seats against a metal seal on the strut housing. With the power on, turn your 4WD on and place the plate against the metal seal on the strut. If the coil is good it should be VERY hard to remove from the strut. If you can peal it right off of the strut, then you will need to replace the magnetic coil.
jrubicon
Where to Ride
Oct 8, 2015 01:05 PM
cody500ho
14
Aug 14, 2015 05:03 PM
toonces
Aug 5, 2015 05:55 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
rcappie4
Jul 18, 2015 07:51 AM
