warrior help
Old Aug 3, 2001 | 10:41 PM
harley22's Avatar
can any one help me out. I have a 2001 warroir with a kn filter and mega max pipe. I tried running a 160,155,150 main jet now I am running a 132 or a 135 . What should I use. HELP[img]i/expressions/face-icon-small-shocked.gif[/img]
Old Aug 5, 2001 | 02:49 AM
Blaster96's Avatar
What is your quad doing? Back fireing through the carb or sputtering under power? I am running a 140 at about 1,200 feet above sea level and have a white bros scielncer and a uni filter.
Do a plug chop. Put a brand new GAPPED b8es plug in it. Run it up and down the road for 5 min at 1/2 to full throttle. If the plug is white or has no color bump up the jetting. if it is black push it down. also if it is a brown color you are getting real close.
Old Aug 5, 2001 | 02:45 PM
ridnwarrior's Avatar
Hello harley22, the stock jet in the quad is a 145. With your mods I'd say run a 148 or a 150. What was it doing when you were running the 150 main jet? We need to know that. How was your spark plug color when running the 150 main?
Blaster96 gave you the wrong plug type information. Do not use an NGK B8ES. That is a 2-stroke plug. Use an NGK D8EA. Gap it at .024" Otherwise follow his instructions on plug color. His instructions are just what I would say. We also need to know your elevation there. Are you riding in the mountains or not? Let us know!
Old Aug 5, 2001 | 10:02 PM
harley22's Avatar
Thanks for the info. When I run on a load in 5 or 6 it wants to go ba ba ba.Like it's getting to much gas.I'll look at the plug on Monday.[img]i/expressions/face-icon-small-sad.gif[/img]
Old Aug 6, 2001 | 12:09 PM
mdegain's Avatar
Hey ridnwarrior,
I know the D8EA is the stock plug for a warrior, but I see D9EA and D7EA's out there also. Do you think going to a hotter burning plug like the 9 will help performance? Or will it make no difference at all? I only ask because I hear of people burning hotter plugs or cooler plugs for whatever reason, but no one ever seems to be able to give me a straight answer. Thanks.
Old Aug 6, 2001 | 03:14 PM
harley22's Avatar
I looked at the plug and it is a medium tan after 3 hours of riding yesterday.What does that mean? I live on the coast.
Old Aug 8, 2001 | 09:11 PM
harley22's Avatar
Sorry I lyed to you guyes. I just looked at my jetting and it is a 140. I just put in a 145 main jet next I am going to try a 150 main jet to see if it does it again.
2001 Warrior
FMF Mega Max
DG Nerfs
KN Filter
Old Aug 12, 2001 | 03:02 AM
Blaster96's Avatar
sorry about the plug. I know it is a d8ea. You could try a d7ea. that is a hotter plug and will make the explotion inside your cylinder stronger. But with the spark plug the way it looks, i would stick with the 8.
If you think it is getting too much gas the 145 will make the machine run rich. i am running a 140 at 1,200 feet and is a tad rich with a WB PM w/ quit core and a uni filter.....
Go down in your jet size a little. try a 137.5
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
