Banshee Leak
Old Aug 4, 1999 | 09:51 PM
Mike Johnson's Avatar
My 96 banshee leaks oil out of the seal where the shifter rod goes into the engine. Its a real small seal. Its a slow leak too. Can i change the seal without taking the engine apart? Im assuming i could just pull the old seal out? If so, where can i get a seal puller for that? Thanx.
96 banshee, 89 warrior
Old Aug 6, 1999 | 03:45 AM
jeffsouza's Avatar
It has been years since I replaced mine, but as I recall, I had to pull the case cover off that side of the motor. The seal pounds out the back side with a socket the same size as the seal (yet smaller than the hole it sits in). It's fairly easy and straight-forward.
Old Aug 6, 1999 | 02:42 PM
jeffsouza's Avatar
On second thought, that might have been for the kick starter. I may have had to split the case on the shifter!!!
Old Sep 9, 1999 | 08:46 PM
BC_Quads's Avatar
I just did mine a couple of weeks ago. It was very easy and only took about 20 minutes. On the left side of the quad, I removed the magneto plastic cover, foot peg and the shifter. I just reached in with a small screw driver and popped out the seal. I then slid in a new seal and presto it was done.
Old Sep 23, 1999 | 09:28 PM
Jetman's Avatar
I did this on mine about a year ago and I just noticed that it's leaking again. I used rtv sealant around the outside in addition to the seal. anybody got any sure fixed for it?
Jeremy
87 banshee, 91 blaster
(both for sale)
exmotocrosser
Sep 13, 2019 06:12 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
bvolks
Sep 13, 2015 12:57 PM
