Warrior troubles ????
Old Aug 11, 1999 | 10:23 PM
lucey's Avatar
I own a 1997 stock Warrior. I seem to have a problem with my top end. It wants to quit when ever i reach the top end in 5th and 6th. If I let off the throttle it will just come to a stop, and die. But if i pull the clutch in it will continue to run, when i let off. This problem doesn't occur all the time. Sometimes it will happen constantly through 10 minutes, and then not again for a while. Has anyone else seen or heard of this problem. Another thing i noticed was, if i don't go riding for a while the problem doesn't seem to occur until the late in the ride, or not even until the next day. Any ideas ??
Old Aug 18, 1999 | 05:31 PM
ZORLOC's Avatar
my first guess if its not getting enough air ?
check the filter and the passage way to the carb.
Chad "ZORLOC" Petersen
96 Yamaha Warrior K&N, Shock wears, WB E-series, AMP Link, Lone star Axcaliber axle, Realtor tires. 97 Yamaha Blaster FMF Ram valve, Bandit rear tires. 97 Yamaha Waveventure 760 STOCK 99 Dodge Ram 1500 360 4x4 ex-cab
Old Aug 19, 1999 | 12:12 PM
lucey's Avatar
I checked all that and it is all clean. I read an article in the new dirt wheels, and there was a 1990 with the exact same problem. They said it was either a dirty carb, or the grounding of the reverse switch. I do not understand why the reverse switch would cause the ignition to stop. Any ideas ??
Old Aug 19, 1999 | 03:43 PM
Harold's Avatar
could it be your stator breaking down under a load(when it gets hot)? Maybe it's a fuel starvation problem, install a clear plastic fuel filter.
Old Aug 24, 1999 | 12:02 AM
JayP's Avatar
I had a problem sorta like that and someone gave me the tip to check the reverse switch and I found my wire was loose. I fixed and replaced spark plug and have not had problem since. I also would like to know how that siwtch has any effect on it running but I couldn't get an explanation. Give it a look.
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Clint Russell
Sep 25, 2015 03:20 PM
Bernhard
Sep 25, 2015 12:45 PM
