Size of replacement tires for Wolverine?
Hello everyone. I'll be shopping for new tires for my Wolverine before too long and I'm not sure what size to get. If I get OEM replacements I have to order them from the dealer because they said only Yamaha can get that size which is:
Front: AT23x8-12
Rear: AT23x10-12
So what size aftermarket tire would fit my stock rim? I'd prefer to go with a larger tire instead of a smaller tire and I ride mostly trails and dirt roads with the occassional mud patch....any ideas?
Front: AT23x8-12
Rear: AT23x10-12
The only after market tire that I have found that offers a stock replacment size is the TITAN 489. They offer the same size as the OEM's on your Wolverine. Arctic Cat's come with the same type of tire(TITAN'S). I have a 99 Wolverine and when I replace the tire's I will use either the Kenda "Bear Claw" or the Cheng Shin "All Trak" in a 25" size to gain more ground clearnce. The only down side to a taller tire is the loss of bottom end, but I plan to preform a few mods to try and gain more HP to make up for the loss...hope it helps.....Herbert
http://community.webtv.net/murdo77/QuadzillaZone
Herbert~~99Wolverine & 89LT520
[This message has been edited by herbert c. (edited 09-01-1999).]
Hey Guys,
If you go with a 25" tire have them put on Aluminum rims. Adding a taller tire saps the power. Sure adding a pipe and air filter help, but alum over steel rims will help performance greatly.
Bruce Crowe
99' Wolverine
99' 400EX
Bruce Crowe
99' Wolverine
99' 400EX
If you go to a taller tire, you will be able to get your performance back by adding some performance pieces/jet kit/air filter/pipe/torque stuffer/air box mods,this will also pick up your top speed to about 58mph,also if you ride in mud etc. buy mudrunners, you will not be sorry!!!!
toonces
Oct 16, 2019 12:11 PM
