Size of replacement tires for Wolverine?
Old Sep 1, 1999 | 02:50 PM
Runnintaco's Avatar
Hello everyone. I'll be shopping for new tires for my Wolverine before too long and I'm not sure what size to get. If I get OEM replacements I have to order them from the dealer because they said only Yamaha can get that size which is:
Front: AT23x8-12
Rear: AT23x10-12
So what size aftermarket tire would fit my stock rim? I'd prefer to go with a larger tire instead of a smaller tire and I ride mostly trails and dirt roads with the occassional mud patch....any ideas?
Old Sep 1, 1999 | 11:24 PM
HERBERT C.'s Avatar
The only after market tire that I have found that offers a stock replacment size is the TITAN 489. They offer the same size as the OEM's on your Wolverine. Arctic Cat's come with the same type of tire(TITAN'S). I have a 99 Wolverine and when I replace the tire's I will use either the Kenda "Bear Claw" or the Cheng Shin "All Trak" in a 25" size to gain more ground clearnce. The only down side to a taller tire is the loss of bottom end, but I plan to preform a few mods to try and gain more HP to make up for the loss...hope it helps.....Herbert
http://community.webtv.net/murdo77/QuadzillaZone
Herbert~~99Wolverine & 89LT520
[This message has been edited by herbert c. (edited 09-01-1999).]
Old Sep 2, 1999 | 12:15 PM
Bruce's Avatar
Hey Guys,
If you go with a 25" tire have them put on Aluminum rims. Adding a taller tire saps the power. Sure adding a pipe and air filter help, but alum over steel rims will help performance greatly.
Bruce Crowe
99' Wolverine
99' 400EX
Old Sep 2, 1999 | 01:51 PM
Harold's Avatar
If you go to a taller tire, you will be able to get your performance back by adding some performance pieces/jet kit/air filter/pipe/torque stuffer/air box mods,this will also pick up your top speed to about 58mph,also if you ride in mud etc. buy mudrunners, you will not be sorry!!!!
Old Sep 5, 1999 | 01:29 AM
thumper4x4's Avatar
I have a modified 95 Wolverine.
I put Bearclaws on aluminum rims, and they work great.
8/25/12 12.5/25/12
toonces
Oct 16, 2019 12:11 PM
coolguy420
Jul 10, 2015 01:17 AM
jettman
Jul 6, 2015 12:16 PM
Jkfx400P
Jul 6, 2015 10:04 AM
Mikea1978
Jul 4, 2015 12:37 PM
