Engine removal
Old Sep 6, 1999 | 01:39 PM
67stang's Avatar
Hey guys,
I was wondering if anybody knows how to remove the bolt for the engine mount that attaches the swingarm and the engine to the chasis? I have everything else disconnected, just that last bolt then the engine will come out. Thanks for any advice in advance.
Kit
Old Sep 6, 1999 | 11:32 PM
Blaster668's Avatar
just pound it out untill the bolt is past the engine mount but leave it stuck through the swingarm a little bit, so it stays up.
Old Sep 6, 1999 | 11:41 PM
67stang's Avatar
I forgot which transportation i was talking about there guys. It is a 98 Blaster. The gear cam broke and i am replacing it myself. I have everything else disconnected. Bolts and hoses etc. Thanks for the advice, but is there a better way to get the bolt out. So that i dont ruin the threads pounding on it. thanks for all the advice.
Kit
Old Sep 7, 1999 | 01:00 AM
HERBERT C.'s Avatar
On mine I used a long 3/8 extension to pound the bolt out. It worked just fine.....Herbert
http://community.webtv.net/murdo77/QuadzillaZone
Herbert~~99Wolverine & 89LT520
[This message has been edited by herbert c. (edited 09-07-1999).]
Old Sep 7, 1999 | 03:45 PM
hot_shoe_cv's Avatar
Stang, I'm not really up on Blaster engine mounts, but depending on how much bolt is projecting after nut removal, use a suitable size socket over the end of the bolt to protect the threads & hit the socket to free it up. Hopefully this will free it before the bolt is no longer projecting from the swing arm. If not, you'll have to use a flat end punch to tap it out the rest of the way.
When you reassemble it you might want to use some Never Seize on it for future removal.
THE AZ. HARD PACKER,
calmiller@kachina.net
save your riding area! join the Blue Ribbon Coalition online @www.sharetrails.org
[This message has been edited by hot_shoe_cv (edited 09-07-1999).]
KimSJoh
14
Jul 18, 2015 07:20 PM
Jul 16, 2015 03:13 AM
clsharky
Jul 13, 2015 02:07 PM
MNatv89
Jul 7, 2015 11:36 AM
Shifts
Jul 3, 2015 07:59 AM
