Torque Reeds????
Old Aug 17, 2001 | 05:56 PM
BansheeBoy2001's Avatar
I just ordered FMF torque reeds and a K&N filter with precharger (to run without airbox) for the blaster. with these mods wiull it have more torque/acceleration and will it be able to wheelie easier in higher gears and last but not least (sorry for all of the questions[img]i/expressions/face-icon-small-wink.gif[/img]) will it in/de crease top end acceleration/speed. Well, thanx ALOT, they will be here monday./g2g cya!
PS::::will i have to rejet?
Old Aug 18, 2001 | 12:24 AM
Motordude0616's Avatar
When I took my airbox off and put in a uni I didn't have to rejet. If you do have to rejet you'll have to go up 5 to 10 points from your cuurent jet.
P.S You'll probably have a tad more acceleration but the big thing that I gained from no air box is the fact that it is alot easier to work on the carb and intake.
Old Aug 18, 2001 | 02:22 AM
Blaster96's Avatar
With my Dule stack boyseen carbon fiber reeds i have tons of low end and can wheelie in every gear. Some not a far as the others but it still does. You will also notic more speed.
Old Aug 19, 2001 | 12:17 AM
EVERY GEAR??? do you have any more mods??? i am hoping to install a pipe/sil. or at least a silencerto kind of even out flow but i really hope mine has the same response as yours does and can pull the wheels off of the ground in every gear! well ttyl cya!
Old Aug 19, 2001 | 01:04 PM
WyoDuner's Avatar
Reeds and K&N are MINOR performance mods. Reeds will not really give you more power but can give you better throttle response at low RPM. The K&N filter will give you a litlte more power but nothing that's going to make any huge difference; you may gain 1 or 2 MPH on top end at most.
A Blaster or any other quad will NOT PULL A WHEELIE IN EVERY GEAR. Maybe get the front wheels light from a bump or rise in the rode but no PULL a wheelie. Reeds NO NOT ADD POWER.
Old Aug 21, 2001 | 08:38 PM
OK i just got some money and i think i am going to get a pipe/sil. what kind do you recommend that works and is pretty cheap and doesnt bust your ears??? thanx everyone for your input!!!
dannytas
Sep 26, 2017 06:31 PM
QuadRiders
Oct 22, 2015 04:13 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Halffast17
Sep 11, 2015 02:30 PM
Jaymc
Sep 11, 2015 07:45 AM
