300EX Clutch problem
Old Aug 21, 2001 | 02:17 PM
Duckman's Avatar
I have a 99 300ex. I used to be able to have it in gear and pull the clutch in and have it start. Now with it in gear it won't start even with the clutch pulled in. Is something wrong with the clutch or the cable or what? If I stall it or shut it off in gear I have to have it in nuetral for it to start again. Thanks for your help!!!!!
Old Aug 21, 2001 | 06:00 PM
KILLER250R's Avatar
Did you put on a different perch ? If so thats your problem becuase there are 2 little wires on the stock perch that prevent it from starting without the clutch pulled in , unles your in neutral. Also If you have the stock perch then check the wires coming out of it to see if there loose or cut or something wrong with them. Good luck ,Zeebo.
Old Aug 21, 2001 | 06:47 PM
bermbanger's Avatar
Mine used to do the same. Turned out the little black box inside there was shot so I just cut the 2 green wires and then connected them, so now mine starts in any gear except reverse, with or without the clutch pulled in.
Old Aug 21, 2001 | 10:35 PM
biggy's Avatar
its probly the mico switch inside your clutch perch housing..cross the wires and see if it starts ....if it does replace the switch....
Old Aug 22, 2001 | 01:03 PM
Duckman's Avatar
Hey, Thanks a lot guys, it was the two green wires that run into the perch that have connectors on them. The one was barely on but it must not have been on enough to make contact. Again Thanks!!!!!!!!!!!!!!!
skinnyr6
Aug 25, 2023 02:18 AM
honda71
Jul 12, 2015 05:56 AM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
honda71
Jul 8, 2015 02:13 AM
