help!!!! Blaster wont idle!!!!!!
Old Aug 22, 2001 | 01:14 PM
trailblazer00's Avatar
I cant get my blaster to idle. Any suggestions?
Old Aug 22, 2001 | 08:19 PM
Grimwikked's Avatar
Chech your air filter,make shure its not real dirty.Check the idle screw and make shure its adjusted properly.Also check that idle air screw is adjusted right,1 1/2 turs out.
If thats not it check your compression.
Old Aug 22, 2001 | 09:49 PM
jmoney45's Avatar
Check your plug also and make sure you didn't foul it.
Old Aug 23, 2001 | 12:54 PM
peterbilt's Avatar
I agree, check out the above suggestions first and if you still have no luck than check out your throttle adjustment, right were your cable goes into the thumb throttle assy. you set it like you would any cable adjustment. well hope that helped!
Old Aug 23, 2001 | 01:20 PM
GJ's Avatar
GJ
If you dont have an in-line fuel filter, you could have some dirt in your carb and it has pluged the primary circuit. you may have to remove the carb and give it a cleaning and blow out all the passages.
Old Aug 25, 2001 | 02:56 AM
Blaster96's Avatar
There is already a fuel filter on the peckcok.
Old Aug 25, 2001 | 01:12 PM
MXFullBoreBlister's Avatar
adjust the idle screw possibly? Mine doesnt idle for more than 10 seconds after its warmed up, but i dont care, its bad to let them idle for very long anyway.
Old Aug 29, 2001 | 11:47 PM
GJ's Avatar
GJ
Yes they have them, but they are just plastic tubes and are a coarse filter. My neighbors banshee had his tubes come off or break off. He found this out when he ran out of gas and switched over to reserve and was still out! the stock tank tube filters are not near as good a filter as an inline type.
Old Oct 4, 2001 | 05:46 PM
98blasterFlash's Avatar
Unscrew the top of the carb and make sure that the tube is not stuck in one spot.
franklyme
Oct 21, 2016 07:18 PM
nastyblaster100
Sep 13, 2015 01:19 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
