wolverine missing
Old Sep 25, 2001 | 01:57 PM
zigzag's Avatar
I just bought a 1996 wolverine the other day,when i rode it yesterday it was fine, today it has a severe miss in it if you apply anything else other than very light throttle. i just dont get it ,it ran fine the other day. any suggestions would be appriciated./ thanks.
Old Sep 25, 2001 | 06:56 PM
Blaster96's Avatar
Make sure the needle in the carb is not stuck open. Also check the spark plug/gap, gas type (+90oct) and make sure there is not water on any electrical connections.
Old Sep 25, 2001 | 08:43 PM
Zorro's Avatar
My money is on the TORS (not sure yamaha calls it the same for the Wolv). Maybe some sensor senses your parking brake is on, or reverse...some little stuff like this.
Real Wolv owners will be able to tell you how to check the parking brake or reverse system...
Old Sep 27, 2001 | 03:39 AM
zigzag's Avatar
well sure enough, i had a little slack in the parking brake as sonn as i took care of that it was fixed... thanks for the advice.
Old Sep 27, 2001 | 08:02 PM
Juice's Avatar
I had that same problem. Sat on the side of a hill for 20 minutes until I figured out I had the parking brake on. Felt pretty stupid after that one.
Old Sep 27, 2001 | 08:41 PM
DeerSlayar's Avatar
I had that same problem too it took me forever to figure it out, I thought I had bubbles in the gas or a stopped up fuel line. Have you checked your top speed for your Wolverine? According to my Etrex the top speeds for my quads are:
Stock 1999 Yamaha Wolverine 350 4x4: 46.4 mph
1986 Suzuki Quadsport 230 w/DG pipe: 49.0
1985 Honda ATC 200S: 46.1
The speed for the Wolverine seems way lower than exeryone elses, I think something must be wrong. I have drag raced a 1998 Honda 300 4x4 and can only beat it in a very long drag race by 1-2 mph. I am not sure if the 300 was stock since its front tires were popping up in 2nd gear, mine were only coming up in 1st. Any suggestions on what could be wrong? My jetting may be a little lean since it gets hot easy. What about using the cheap gas? Any help would be appreciated.
95wolv
Sep 27, 2024 12:00 PM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
panicmanic
Sep 28, 2015 12:59 PM
tysonbully
Sep 28, 2015 02:30 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
