Just installed Dura Blue axle on Raptor. Whats up with this.......
Old Sep 27, 2001 | 06:54 AM
gogojoe's Avatar
It took all of about 15 minutes, no problems, everthing went just fine, BUT....am I crazy or does this axle make the right tire stick out about 1/2 inch more than the left. What the farf. Oh BTY, its a Eliminator 2+2. I have seen in a lot of signatures that others have installed this and was wondering if anyone has seen the same. Actually, its no big deal, I can just make new spacers to correct this.
Old Sep 27, 2001 | 08:42 AM
NotuRaptor's Avatar
I know you didn't buy this because this would not be a cheap a$$ mod...so didn't you notice that you swiped it off a Banshee and not a Raptor? Well since you already have it, you need to swipe some washers and space it evenly.
Old Sep 27, 2001 | 10:48 AM
300exSTER's Avatar
Hey man,
I have a 440ex with a lonestar +4 axel, when i installed it i thought the same thing, its about an inch longer on the left side! But then come to find out, if you take off the Axel nut it looks the same, the nut makes it look shorter on that side. I even measured from the swingarm to the inside of the tire..sure enough, i was wrong it was even just the nut threw it off
hope this is your solution
ryan
Old Sep 27, 2001 | 11:09 AM
vraptor's Avatar
I thought the same thing when I put mine on, but when I checked and measured it was as it should be. The good thing about the newer dura blue is they have the "improved" axle nut, my buddy got his 2 months ago and it has a different setup which does come loose, mine stays tight
fordfaithful21
Dec 7, 2015 05:52 PM
alzgarvin
Sep 11, 2015 08:53 AM
1000gade
Sep 9, 2015 04:41 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
