Warrior won't roll
Old Sep 30, 2001 | 01:20 AM
Spuds's Avatar
A friend of mine has a 98 warrior, and in neutral the thing will not roll . You can push it but it is extremely hard to push. We pulled the chain and the axle is free but the front sproket can not be turned by hand. the machine runs fine and will freely shift trough the gears. Some one told us the shift forks needed to be adjusted. Has anyone had this problem? and can it be corrected without complete teardown?
Old Sep 30, 2001 | 02:20 AM
bsr's Avatar
bsr
Brad if yours dont move with the clutch in that means your clutch is adjusted to tight. Or your clutch might be going bad...
Old Oct 1, 2001 | 12:15 AM
Spuds's Avatar
Well we found the problem, after a complete tear down , we found a needle bearing that had work out of the case and was putting the trans. shaft in a bind. the bearing presses in the case half, but it had worked it's way about 1/4 of the way out.
Old Oct 1, 2001 | 12:44 AM
lonestarbanshee's Avatar
Where you crash at Spuds?(whats your hometown)
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
01ssls1
Sep 22, 2015 06:50 AM
Albertaboyy
Sep 9, 2015 09:51 AM
