Smoking
It's probably just condensation from the warm exhaust combined with the moisture in the system when it hits the outside cold air.
THE AZ HARD PACKER, calmiller@kachina.net
save the public land FOR you, not FROM you..join the Blue Ribbon Coalition online @ www.sharetrails.org
Its most likely your valve stem seals seaping oil, not a major prob. What kind of oil are you using, and do you change it often?
http://www.geocities.com/norcalatv
Usually will happen until engine warms up and piston/rings expand to form good seal. As long as it stops after warm, don't worry. Like the other post stated, could just be moisture. As long as you are not burning oil and the smoke is not blueish...I also recommend starting your bike and letting is warm completely before you go speeding away. I see several guys where I ride start a cold engine and rev the snot out of it and take off full throttle.. Not a good idea unless you like to rebuild motors.
jrooker6
Apr 23, 2016 07:36 PM
