When a CV Joint Breaks in the Middle of a Ride???
Old Oct 12, 2001 | 11:18 AM
walexa's Avatar
I was just wondering what you guys do if you break a cv joint in the middle of a long ride......just ride it with hit jerking and popping?
Old Oct 12, 2001 | 11:37 AM
DJ425's Avatar
When mine broke, we pulled it out, and drove on. Only three wheel drive though. If you carry enough tools it isn't that hard to do.
Old Oct 12, 2001 | 11:46 AM
walexa's Avatar
DJ425,
When pulling it on the trail, do you just knock the roll pin out, and pull the shaft off from the front gearbox, or do you also have to undo the a-arm to get enough room to get the joint out? Thanks. Also, are there any tricks you've found to removing the roll pin or any other tricks about any of it?
Waylan
Old Oct 12, 2001 | 12:42 PM
MEANGREENMACHINE's Avatar
When i break a cv joint out on the trail i just remove the shaft and leave the rest of it in the hub. The best way and easiest way i have found to get the roll pin out is to rotate the shaft until you can see it's level with the bike. You should be able to see it through the hole in the bottom corner of the bash plate. I just take a long phillips screwdriver and hit it with a hammer. I keep tapping it and it pops right out. It's very simple and takes about 5 minutes.
Old Oct 12, 2001 | 01:11 PM
walexa's Avatar
Thanks for the replies.
There's a place in my hometown that rebuilds the joints to be heavy-duty, and they warrant their internals for life, and used to warrant the whole joint.......but they told me that they have had some joints come back with the housing busted........not the internals. Therefore, they only warrant the guts.
They take your joint (shaft and all), and do some machining of the housing and all to accept a beefier cage, knuckle, and *****. They put it all back together and put a plastic-style boot back on that is supposed to be much more durable than the rubber ones. All that for $200 per side.
I want to go this route, but not before I break the stockers......not that they're gonna break, but you know what I mean.
Every year, there's a 17-mile ride in a swamp that I attend, and I posted this topic to see what to do if I'm at milemarker 10 and break one. Anyway, thanks again for the replies.
Waylan
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
MikeyBoyesq
Nov 27, 2020 02:44 PM
Frisky2050
Apr 9, 2020 11:19 AM
sara durrant
Jul 6, 2015 05:32 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
