Removing Shifter
Old Oct 15, 2001 | 08:11 PM
bermbanger400's Avatar
i have noticed in some of the pics ive seen on the web that some of you guys has removed your shifter can you just run a piece of alum. out the side from the tranny and shift it like that? or would you not be able to shift it then?
Old Oct 15, 2001 | 10:18 PM
elroy's Avatar
I had my shifter linkage off once because I broke one of the rods while trying to change the one end. If you added a short piece of metal off the end of the shift lever coming out of the tranny, this should give you enough leverage to shift. I used a small pair of vise-grips. I hooked my linkage back up once I replaced the broken piece. I only really hooked it back up because I have low range also. If I didn't have low range, I probably wouldn't have hooked it back up. I would have had to come up with something a little more permanent than a pair of vice-grips.
Joe454
Nov 20, 2020 01:19 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
EIF
Apr 20, 2017 07:15 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
