Elec. Accessory Outlet
Old Oct 16, 2001 | 08:55 AM
blades's Avatar
I have a 2000 SP335 which has the lighter plug elec.outlet. I want to use my cell phone and CB from this outlet. How can I use the power without having the entire electrical system "live". If I leave the ignition key on, the rear light stays lit, etc. Has anyone found a way around this?
Thanks
Gary
Old Oct 19, 2001 | 12:55 AM
andyems's Avatar
I have a 2002 SP 500 and when I want to run the cooling fan w/o running the taillight, speedo light, etc, I just use the kill switch to shut off the motor, and never tough the ignition key to kill it, leaving the actual ignition switch on. This leaves the fan on so when I stop and turn off the motor, the fan will run and cool it down, while shutting off everything else. It also runs power to the socket with this procedure, so when I shut off the kill switch, the only thing with power is the cooling fan and the power outlet. I tried it last night to see before I replied. Granted mine is a 2002, but it might work the same. Hoped this helped. Good luck !
Old Oct 19, 2001 | 01:09 AM
Scaryfast's Avatar
I can't wait to try that on my quads. I always leave the key on until the fan shuts down. Great information!
Old Oct 19, 2001 | 09:40 AM
Hillcat's Avatar
That is a great suggestions. Thanks.
Old Oct 21, 2001 | 08:46 AM
blades's Avatar
Follow-up on my original message. Tried using kill switch while leaving key on- it completely shut down the elec. system, no power to outlet.
Problably works on SP500 because of coolong fan, but not on SP335. Thanks for the good info.
Old Oct 21, 2001 | 02:30 PM
BLH's Avatar
BLH
Don't know if you want to do this, but you could rewire that outlet or wire in another one. Just run the (+) wire from the battery, and ground it anywhere. You'd always have power, and it wouldn't draw unless something was plugged in....
Old Oct 21, 2001 | 07:38 PM
500DUSE's Avatar
Killing the kill switch on my 01 500 kills everything.
carid
Sep 14, 2015 03:40 PM
PrairieDog126
Sep 12, 2015 05:23 PM
braap123
Sep 7, 2015 12:58 PM
Captjay
Jul 23, 2015 12:33 PM
prarie-dog
Feb 9, 2000 05:53 PM
