Too much oil = Engine overheat
Old Oct 20, 2001 | 07:25 PM
92LT's Avatar
Will too much oil cause an engine to overheat?
My prairie 650 overheated several times today. I checked the oil and there was too much. Could this cause the motor to overheat?
Old Oct 21, 2001 | 01:43 PM
WyoDuner's Avatar
Technically speaking I think it could. When the crank & rod have to push through the extra oil it puts a big strain on the motor...
Old Nov 9, 2001 | 11:26 PM
dynamoD's Avatar
Yes too much oil in the crankcase will cause engine to run hotter than normal,the oil will foam and lose its ability to cool.
Old Nov 12, 2001 | 09:47 AM
Backcountry's Avatar
Speaking along the lines of Two Strokes--Yes. Here's why for those interested:
Too much oil will effectively lean out the mixture and cause overheating. The oil has displaced the gasoline, which is the same as decreasing the jet size, less gas = leaner mixture. Additionally with less gasoline there is less evaporative cooling. The evaporation of gasoline on hot parts does a tremendous job in keeping the components cool. Further the specific energy of the oil is likely to be higher than that of gasoline, again a hotter burn...so all around pretty much too much oil and not adjusting the jetting to suit can lead to a lean condition, and lean conditions can manifest as overheating.
This is a classic example of people who see it fit to add more oil to their engines when they are breaking in a new top end and do not adjust to that additional "helpful" oil. It's not all that a bad practice to do, but you HAVE to adjust your jetting to suit.
Now as for a thumper that is overheating with too much oil. The other guys have got it...
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
austinwhitton
Aug 11, 2015 06:21 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
