Too much oil = Engine overheat
Speaking along the lines of Two Strokes--Yes. Here's why for those interested:
Too much oil will effectively lean out the mixture and cause overheating. The oil has displaced the gasoline, which is the same as decreasing the jet size, less gas = leaner mixture. Additionally with less gasoline there is less evaporative cooling. The evaporation of gasoline on hot parts does a tremendous job in keeping the components cool. Further the specific energy of the oil is likely to be higher than that of gasoline, again a hotter burn...so all around pretty much too much oil and not adjusting the jetting to suit can lead to a lean condition, and lean conditions can manifest as overheating.
This is a classic example of people who see it fit to add more oil to their engines when they are breaking in a new top end and do not adjust to that additional "helpful" oil. It's not all that a bad practice to do, but you HAVE to adjust your jetting to suit.
Now as for a thumper that is overheating with too much oil. The other guys have got it...
KimSJoh
14
Jul 18, 2015 07:20 PM
