Sticking in Gear
Old Oct 23, 2001 | 05:21 PM
SilverOne's Avatar
When I am in either low or high range and get into a bind I have hard time getting into reverse. Sometimes after wheeling in low I have a hard time shifting back to high. It seems to stick or bind in gear and will not go out of that gear. I just had a new drive clutch put on and it still does this. Any suggestions?
'01 500 HO
Old Oct 23, 2001 | 05:40 PM
4wheelitis's Avatar
Check or have your shift linkage adjusted. These rods being out of adjustment will cause the same type of problem. Good luck
Old Oct 23, 2001 | 06:00 PM
500DUSE's Avatar
4wheel is right,it's in your linkage.
Pull your right side cover off,change gears untill it does.Look at the shift rods to see which one it is,then adjust the nuts accorddingly.
It just takes a little fiddleing
Old Oct 24, 2001 | 10:29 AM
Farmr123's Avatar
Could also be the idle set too fast. This causes the front pulley to put just a little drag on the belt (it is worse if the belt is new, too). This puts a bind on the shifter through the transmission.
Old Oct 24, 2001 | 10:41 AM
SilverOne's Avatar
Thanks for the suggestions. I'll give them a try.
Old Oct 24, 2001 | 12:54 PM
weedy's Avatar
'5 minutes worth of planning equals 30 minutes of execution'
Simple linkage adjustment. My dealer adjusted mine in a matter of minutes.
mywifesquad
8
Sep 21, 2015 08:20 AM
merryman
Sep 6, 2015 10:20 AM
Haakon
Aug 24, 2015 01:54 PM
mbkirk
Aug 14, 2015 08:20 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
