exuast for 250EX?
Old Oct 23, 2001 | 09:42 PM
250EXRiderJamie's Avatar
Does anyone know of a good pipe and air filter for the 250EX?
Old Oct 23, 2001 | 11:21 PM
BK's Avatar
BK
The November issue of Dirt Wheels has an article on hopping up the 250EX. It has pipe filter and jet sizes as well.
Old Oct 24, 2001 | 04:55 PM
someone that has a 250Ex should be able to answer that has a new exaust
Old Oct 24, 2001 | 06:00 PM
superman28's Avatar
Do you really think your gonna get any performance out of a 250ex? This quad is one of honda's major screw ups. You can't classify it as a high performance quad, because it lacks the "high performance". You can't classify it as a utility quad because of the weak *** engine and It doesn't have 4wheel drive. So could someone please tell me what qualities this quad brings to the table.
01 400ex yellow
pro circuit T4 exhaust
renthals
AC pro pegs
shockwears
Old Oct 24, 2001 | 06:29 PM
SparkyEX's Avatar
1. automatic clutch that rules for tight trails, hillclimbs and learning to ride.
2. Shaft driven - No chain to worry about, adjust, or keep clean.
3. Great for wheelies
4. Great on gas
5. Reverse
6. Reliable
7. $3800 OTD
Now, I'm not saying it would beat your 400ex on the track but you would be hard pressed to keep up on tight trails.
Old Oct 24, 2001 | 07:19 PM
not only that the 400ex is terrible for trails!!!!! the quads ground clerance is too small to go over like a 3 inch rock! and i got my quad for trails mostly and its not like you race!!!
Old Oct 24, 2001 | 08:36 PM
superman28's Avatar
You guys are crazy! The 400ex is one of the best trail quads ever built. The handling on a 400ex kills the tight trails.If you get on some trails where you can get your speed up and you try to make tight turn the 250ex with its shorter wheelbase and balloon tires, your just asking to flip the bike. Go out on trails and tell me what quad you see the most? I can tell you what I see the most and thats 400ex's. If you get on some really technical trails your 250ex will not make it. 2 reasons:
1. If you get into some mud, the weak *** engine will not get through it.
2. Theres not enough weight to it. When you do get into the mud your just going to be floating on it instead of getting some traction.
01 400ex
AC pro pegs
renthals
Old Oct 24, 2001 | 09:36 PM
250ex's Avatar
i love my 250ex. last winter while riding on snowy trail it hauled. Most of the 2wds were getting stuck or slowed down but i flew. It is a good trail machine i can lose others or stay right on them. i like 400's especially for jumps but i like reverse.
BK's Avatar
BK
Superdud 28
Why put down a machine you obviously know nothing about? There is nothing weak about the motor on the 250EX. It gets great power out of its 229 cc's. It does great in the mud, the light weight helps it stay on top instead of getting buried. In technical stuff the auto-clutch lets it do things your manual can't do without a lot more work. It is a fun, manueverable machine that does a lot of things well. I'm sure your 400 is a fast (and probably annoyingly loud) machine. However, unless your riding skills exceed your mental prowess, you probably aren't using its potential anyways. If you can't add something positive to a discussion why not improve the forum by keeping your mouth shut and not putting down someone else's machine? [img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Oct 25, 2001 | 01:22 AM
superman28's Avatar
Power out of a 250ex? whats it put like 10hp? They took a damn honda recon engine and flipped it sideways. Quit being such a puss and get off the entry level quad and get something with some *****.
01 400ex
Pro Circuit Exhaust
AC Pro Pegs
Renthals
