how to cut fenders on Mojave help
Old Oct 24, 2001 | 07:18 PM
GreenMachine01's Avatar
How to cut front fenders. So it looks good.
Old Oct 24, 2001 | 08:08 PM
rockrider's Avatar
You can use a handheld scroll saw (is that the right name?). I have one at home and if you switch out the blade to the one you need it makes it easy to make neat, accurate cuts. Just follow a contour on the existing fender as a guide. Also, chek out some magazine pictures to get an idea of what kind of look you want.
Old Oct 24, 2001 | 08:55 PM
madweazl's Avatar
I used a sabre saw for the initial cut and then went to a hand file to knock it down where I wanted it. After that I made it look nice using an orbital sander and a fine grit sand paper. You can see some pics of my Mojave in the signature below.
Old Oct 25, 2001 | 08:58 AM
mordr's Avatar
A dremel tool with a metal cutting disc was used on mine-no sanding needed, but I did use a razor blade to clean up some edges. It made a very clean, easy cut.
Old Oct 25, 2001 | 10:43 AM
madweazl's Avatar
Wow, a Dremel? Didnt that take forever? Those are some big fenders, I give you props because that sounds like a job!
Old Oct 25, 2001 | 10:52 AM
mordr's Avatar
A friend of mine actually did the cutting-he had done it before and did a really good job. It cut thru it like it was warm butter. It really went pretty fast-shot green "sawdust" everywhere.
fd24
Jan 16, 2019 08:59 AM
mywifesquad
8
Sep 21, 2015 08:20 AM
89Lt250r
Sep 7, 2015 07:53 PM
mrmickman123
Technical and How-To Articles
Aug 30, 2015 10:37 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
