rear outer cv boot cover replacement???
Old Oct 29, 2001 | 04:50 PM
lovepalace's Avatar
can someone tell me how to take the cv joint apart to replace the boot cover. I have a 99 sportsman 500.
Tanks for your help.
Old Oct 29, 2001 | 06:59 PM
500DUSE's Avatar
If you do a search on"cv boot" in polaris only you'll see
About to change cv boot,any tips?
Read that one,the last one I wrote was how everything went at the end.
If you have anymore ???'s let me know
Old Oct 30, 2001 | 01:50 PM
lovepalace's Avatar
IT'S NOT WORKING! This is frustrating. Why do the simple tasks always turn into the worst nightmares? I'm no mechanic but I'm not an idiot either. I've tried YANKING, PULLING, PRYING, PINCHING and I still can't get the shaft of the bike or the CV joint apart. Why me? What could I possibly be doing wrong?
...HELP....
Old Oct 30, 2001 | 02:50 PM
Farmr123's Avatar
Keep in mind that the joint is held onto the shaft by a little snap ring. It is hard to find because it is small, and covered with grease. Pull the old boot back from where the joint and axle connect, dig through the grease, and you should find it. You will want to pry the ends of the snap ring apart, and the axle should pull loose from the joint. If you don't have snap ring pliers, a small flat blade screwdriver works, SOMETIMES.
When putting it together, be sure the snap ring locks everything back together tight, then put the boot on all the way, & tighten it up.
Good luck.
Old Oct 30, 2001 | 06:18 PM
500DUSE's Avatar
YEAH,What Farmer said.
I just used a screwdriver to wedge it apart.
It's a pain in the *** the first time but once it comes apart you'll say ....OH YEEEAAAH.
Just fiddle with that snapring.
I had to walk away and come back when I calmed down some.
Old Oct 31, 2001 | 02:46 PM
lovepalace's Avatar
Hey, Thanks for the help!
Once I found the ring every thing else was a snap!
Thanks to the internet and forums like this, you guys have saved me big $$$ and several trips too the local dealer.
Thanks[img]i/expressions/face-icon-small-happy.gif[/img]
rcappie4
Jul 10, 2015 04:54 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
Rider252
Jul 6, 2015 03:37 PM
jettman
Jul 6, 2015 12:16 PM
