DS650 GPS/Radar Speeds
Old Nov 18, 2001 | 11:56 PM
ScoobyDFW's Avatar
Post your measured speeds.
GPS: mid eighties @ 1000 feet on dirt. (still getting the bugs out)
Old Nov 19, 2001 | 12:25 AM
Hurycne's Avatar
You ride with a guy named Buzz that rides a bad *** Banshee?
Old Nov 19, 2001 | 12:28 AM
Hurycne's Avatar
Hey where are you riding your DS at?
Old Nov 19, 2001 | 09:49 PM
ScoobyDFW's Avatar
what mods does he have?
Old Nov 28, 2001 | 06:12 PM
ScoobyDFW's Avatar
Does anyone with a modified DS650 have 1/8 and 1/4 mile times and speed? This is another way to compare HP without the hassle of a dyno.
Old Dec 9, 2001 | 02:34 PM
ScoobyDFW's Avatar
I easily made it into the eighties (E-trex GPS) in deep loose sand this weekend, running 22x11x10 10-paddle taller haulers which load the motor quite a bit. It's not the max speed due to limited drag strip length. The head gasket keeps leaking though. I need to O-ring the cylinder. There were some turbo banshees runnning 25psi of boost. I don't know if I'm sold on the taller haulers for my turbo setup yet - the added traction/loading has it's negatives.
Old Dec 9, 2001 | 05:39 PM
RaptorRRC's Avatar
ScoobyDFW, was that sand run at LS? I read in one of your other post that you were thinking about realtors and also read another guy was using them and like them. I have a set only (used once) if you are interested. 22x12x9.....Let me know
Old Dec 9, 2001 | 08:59 PM
buttfungus's Avatar
RaptorRRC, did you try the realtors in the sand with your rappy? How do they perform on hard pack and in sand? Would they work at Kermit or Little sahara in OK. ?
Thanks,
Old Dec 10, 2001 | 02:25 AM
RaptorRRC's Avatar
The realtors were originally bought for a 300ex but the were too much tire for it. My son did try them on his Raptor once but the did not compare to the sand skateII's and he only did one run on them. He should have ran them more to get used to them. They did break loose and got no traction on that one and only run. Being a taller tire if he would have played with them and got them to hook up there should have been some good runs. I can see where they would be good but we just never did try them out in other conditions. We were thinking about waiting for snow (rare) or mudding with them too. They should work great in sand with the big power wheelers like the DS.
Old Dec 10, 2001 | 12:05 PM
QUADMXer's Avatar
I thought this post was for measured speeds not tires. I am interested in what speeds you guys are getting with your modified setups (thanks for your input Scooby). Whatever the speeds are though it's never enough is it.
Pehter
Oct 3, 2024 11:00 PM
ReconBayou
Sep 23, 2015 02:41 PM
mywifesquad
8
Sep 21, 2015 08:20 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
