Down shift prob on 250sx
Old Nov 26, 2001 | 02:51 PM
tysick's Avatar
Hi everyone just wondering if anybody has had this happen to any manual shift Honda's when I downshift the gear selector sticks between gears and I have to either pull up on it a little bit or stamp on it alot for it to release. It changes fine 1 through 5 up only when I go down through the gears it does this which is a little scary when going done hill and you shift to a lower gear for engine brakeing and all the sudden your freewheeling between gears. Any fixes for this would be helpful Thanks.
Old Nov 26, 2001 | 05:09 PM
Woodo68's Avatar
I have a similar problem with one of my 250sx's. The gear shift lever sticks going up and down. The tech at my local dealer told me to run tranny fluid in the engine for 10 minutes and then replace with normal oil. The hope was that the detergents in the tranny fluid would relieve the sticking. I did it and did not notice much of a difference. To solve the problem I connected two springs to the shifter. One spring pulls up the other pulls down. After a little tweaking of the springs the bike shifts like normal. It's not the best fix but until I find a better option it has to work.
Woodo
Old Nov 27, 2001 | 09:22 AM
tysick's Avatar
Thanks for the info I have had this bike for 10 years and never a prob all I have ever done is change the brakes and bearings on right rear end axle and a throttle cable. Did all the work myself cost maybe 200.00 bucks for everything not bad for 10 years worth of riding. I was just hoping I didn't blow the shifting fork or something major in the trany when she started to stick.
Old Nov 27, 2001 | 01:58 PM
Woodo68's Avatar
Yeah SX's are tough Trikes. I've had mine for 15 years and rode it real hard the first 5. Then I got my R and the SX turned into the Friend/Girlfriend bike. If you don't have an owners manual for it the link below may be of interest to you.
Woodo
http://www.3wheeler.org/tech/250sxManual/Contents.htm
Old Nov 27, 2001 | 04:56 PM
tysick's Avatar
Thanks for the info thats an awesome site I posted my question in there also just in case some body else has seen the same trouble I will try the trany fluid idea though.
95wolv
Sep 27, 2024 12:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
patrick.oc123
Sep 16, 2015 03:45 AM
BigCam
Sep 16, 2015 01:53 AM
patrick.oc123
Sep 15, 2015 02:45 PM
