trail breaker tires
Old Feb 3, 2000 | 01:09 PM
Hoss's Avatar
any one heard as to whether those trailbreaker awd tires are any good
Old Feb 3, 2000 | 04:32 PM
Brian_Kimmel's Avatar
A buddy of mine has the Trailbreaker ATV tires on his Yamaha and they work GREAT. I would think that the Trailbreaker AWD would be just as good. The only real difference between the Trailbreaker ATV, and the Trailbreaker AWD tire is that the ATV tire has the vertical tread that runs down the center, and the AWD does not.
Old Feb 3, 2000 | 05:19 PM
Stump's Avatar
I was wondering the same thing. Is there a web site out there anywhere I can look at them and get specs. Ply, weight, and other stuff.
Old Feb 3, 2000 | 11:20 PM
Try this site. www.diprimatire.com/atv.htm
Old Feb 6, 2000 | 08:24 AM
doug_blackburn's Avatar
I had great luck with the McCreary tires on a Bayou 300 4x4. They have been on the machine better than 6 years with no flats and plenty of tread left. The difference between the ATV and AWD is their intended application. The ATV is designed for use on the rear of two- or four-wheel drive quads. The center tread is there to smooth out the ride on hardpack and lend increased sideways traction for sliding or off-cambers. The AWD is solely intended for use as a front tire for 4X4's. It's design boasts increased cleaning and traction. There is little weight difference, but they will measure a bit bigger than stock. Make sure your quad has enough power to pull the larger circumference.
RickyMac
Mar 5, 2016 07:27 AM
velcro7279
Aug 24, 2015 01:15 PM
Jul 24, 2015 11:57 AM
baysport
Jul 23, 2015 11:37 AM
toonces
Jul 21, 2015 02:40 AM
