warrior help
Old Dec 3, 2001 | 08:49 PM
Tooey's Avatar
i have a 97 warrior okay. and when i push the start button it just sits there and clicks is it my starter relay or the bearing in the starter??
Old Dec 3, 2001 | 09:10 PM
KNOWSALOT's Avatar
The Facility
Is it the relay clicking or the starter clicking?
If it is the relay clicking, first turn your key on, then cross the two posts on the relay with a screwdriver. If it cranks,you need to clean the connections and try again, and if after cleaning it,it still only cranks with the screwdriver,you need a relay. If it doesn't crank try cleaning all your connections,battery posts,and starter terminals. Also make sure that your battery is still charged up.
If it is the starter clicking, you will have to remove it and find the problem within the starter.
KNOWSALOT
Old Dec 4, 2001 | 10:08 AM
NEMISIS's Avatar
my 96 warrior did that when the battery started to go dead..the battery had just enough to make that clicking sound.
i suggest you hook up some jumper cables and see if it will start. good luck
Old Dec 4, 2001 | 11:35 AM
earthraper's Avatar
My .02: DO NOT JUMP START
Get another battery and try that. You risk seriuosly hosing your electrical system by jumping it. You might not, but is it worth the risk?
Old Dec 4, 2001 | 06:41 PM
FISHER1648's Avatar
I found that cleaning up the start switch helped a lot. Dust will get in there and cause arcing. Open it up and check it out - it's quick and easy.
Old Dec 4, 2001 | 06:52 PM
ChevyGuy's Avatar
MY warrior made that noise when my starter went out.
Old Dec 4, 2001 | 08:12 PM
MUDMAN2k1's Avatar
I know this is a polaris but my trail blazer did that when the starter went out
Old Dec 4, 2001 | 08:26 PM
NEMISIS's Avatar
you right ..i did jump mine with a boat battery and it didnt hurt it ..but it can melt the wirrering..so dont do that..i retract my suggestion
Old Dec 4, 2001 | 09:17 PM
Tooey's Avatar
it don't even crank when i cross a screw driver on the relay.. i think it may be the prob.. i will start by popin it, i am about ready to buy a honda..
Old Dec 8, 2001 | 01:29 AM
immfwarrior's Avatar
Did your starter ever sound sluggish? Sounds to me like you might of cooked your brushes. take a set of battery cables and hook the battery direct to the starter. If it won't turn you'll need to pull the starter get new brushes (comes as two parts) and inspect the armatour. It may need t be turned down unless it is too bad.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
