What Plug For My Banshee
Old Dec 6, 2001 | 11:43 PM
MattFL's Avatar
I have a stock 2000 Banshee. I bought ot used and it has a NGK BR8EG in it, which is the wrong plug. NGK says to use a B8ES, B8EV(Fine Wire), or a B8EVX(Platnum). Should I get the regular B8ES or go for the VX version? Any idea how having a resistor plug hurts or helps?
Thanks...
Old Dec 7, 2001 | 12:14 AM
JoshCVBz's Avatar
Matt,
Yeah, just run the BR8ES or the B8ES...doesn't matter. The only thing that the resistor does is reduce electromagnetic interference that can screw up on board electronics. I think that they are mainly designed for cars because of the computers that control the fuel systems (they can be very sensitive to that stuff). As for a Banshee? I don't think you have to worry about it.
I run the BR8ES (or B8ES) in my Banshee and it hasn't fouled one yet (been in there for a long time). The only time you would need to switch to the higher priced plugs is if you have been fouling the other ones. You won't see much of a performance difference between spark plugs so don't believe all of that hype. In such a small horsepower motor the gaines probably aren't even measureable.
Hope this helps.
-Josh
Old Dec 7, 2001 | 12:22 AM
JoshCVBz's Avatar
Oh by the way...your EG plug that you have in it is mainly used for racing applications. On a stock Banshee I don't think that there will be a performance difference between the G and the S.
-Josh
Old Dec 7, 2001 | 08:21 AM
MattFL's Avatar
Thanks Josh, I wasn't expecting any real performance gain, just hoping for quicker starting. Still starts in 5 kicks when sitting for two weeks, even with the old plugs. Guess I'll just sick up some B(R)8ES...
Thanks again
greek271
Aug 8, 2015 08:16 PM
JohnnySplat
Aug 6, 2015 12:07 PM
Captjay
Jul 23, 2015 12:33 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
Jul 7, 2015 11:00 PM
