How to Hand-polish Aluminum parts???
Old Dec 24, 2001 | 11:38 AM
AdamScramblr400's Avatar
I've seen a lot of people that have hand-polished a lot of their aluminum ATV parts, and I was wondering How to do this. Can I do it successfuly on my swingarm skidplate, HPD pipe, and my stock silencer? Thanks.
Old Dec 24, 2001 | 01:29 PM
Quadfather's Avatar
Get a small tub of Mothers Aluminum ploish. Put a small glob on a rag, and rub the snot out of it. It will look better than new. Keep a lot of rags handy. It's kind of messy, but worth it.
As far as the pipe goes, I used Simple Green, and a scotch bright pad. Use the Mothers on anything aluminum. I'm taking for granted you have a nickel plated pipe.
Old Dec 24, 2001 | 04:39 PM
GAR's Avatar
GAR
Try a product called Heavy Metal, works much better than Mother's with half the rubbing or buffing. Comes in three different formula's.
Old Dec 26, 2001 | 12:16 PM
MEANGREENMACHINE's Avatar
If it is painted you need to remove the paint first. The easiest way i have found is a wire brush that attaches to a drill. It removes everything quickly. Then use some 200 grit all the way up to 800 grit sandpaper and keep sanding until it becomes nice and smooth. Then get a buffing wheel either attatching to a grinder or drill and some buffing rouhge. Then buff the hell out of it. It takes time but the longer you do it the better the shine. I did the whole motor on one of my trikes and it took about 5 hours every night for 2 weeks. It is definitely worth the work.
Old Dec 27, 2001 | 05:59 AM
Duneman09's Avatar
If you need to remove paint or clear coat prior to polishing use hardwood floor stripper and a cheap paint brush to remove the paint or clear coat. No scratches, less work. Oh, and be certain to use rubber gloves. You can also send to Eastwood Automotive for a video on polishing which is worth it if you're going to get the "polishing bug". You'll have to search for the web site. ( And I think Eastwoods is now owned bt Sears. )
toonces
Aug 5, 2015 05:55 PM
toonces
Aug 3, 2015 09:59 AM
toonces
Jul 28, 2015 01:58 PM
WilliamBos
Jul 25, 2015 02:41 PM
Sandman2.0
Jul 21, 2015 09:03 AM
