Removing Gaskets?
Old Jan 26, 2002 | 04:44 PM
ltracerx's Avatar
Hey guys I got my Gaskets and piston in the other day but anyway, I need to know how to remove all the gasket material that was left on the surfaces of my cylinder. Is there some sort of "Gasket Remover"? Any help appreciated.
Old Jan 26, 2002 | 04:50 PM
MEANGREENMACHINE's Avatar
I always use a wire brush that attaches to my drill and a razor blade. That has worked the best for me. Good luck.
Old Jan 27, 2002 | 07:16 PM
ltracerx's Avatar
Anyone else have any tips?
Old Jan 28, 2002 | 02:12 PM
trx450's Avatar
There are several chemical products out there that you can use. Go to the auto parts store and ask for Permatex Gasket Remover. DO be careful when cleaning the old gasket off your case halves. On real stubborn baked on stuff, try a single edge razor blade as a scraper.
Old Jan 28, 2002 | 02:27 PM
ltracerx's Avatar
I got all of the gasket material off of the reed cage and cylinder, I used one of those wire brushes to clean your BBQ, but I still haven't got it off the cases yet. I guess I'll have to try out the Gasket Remover but I really don't want to because I'm sure it will get in the bottom end, then I'd be screwed.
Old Jan 28, 2002 | 02:32 PM
trx450's Avatar
Put a CLEAN cloth in the cases. Then CAREFULLY work at removing the gasket. Do you have a shop-vac? You could use it to suck up the gasket "crumbs" as they come off. Take your time, it can be done. I've done it dozens of times.
1ArmBandit
55
Oct 14, 2015 09:03 PM
clscott84
Sep 21, 2015 10:16 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Minimod
Sep 10, 2015 09:20 PM
Minimod
Sep 10, 2015 08:03 AM
