lakota
Old Feb 13, 2000 | 02:51 PM
sl250r's Avatar
i was wondering if anyone knows of any good preformance mods for a lakota. i mostly ride wooded trails and in the strip jobs i also go mudding i have surtrack tires they almost hit the battery so would spacers be a good investment.but i need a more top end without loosing the low end
Old Feb 16, 2000 | 09:36 AM
98Lakota's Avatar
I have a 1998 Lakota with a manual clutch kit, DG Pipe with SuperTrapp discs, UNI Filter, jet kit and Douglas 190's with Holeshots(they are 20x11x10 and they are about 1/4 inch from the battery and rub occasionally) I can easily keep up with a 300 EX with basically the same mods. It does great in mud, but i think it would do better with different tires.
Ask if you need to know more.
Old Feb 21, 2000 | 03:10 PM
sl250r's Avatar
so nobody elese has a lakota with mods
Old Feb 22, 2000 | 10:04 AM
vlucdog's Avatar
99 lakota douglas 190's, alltracks (rear) front pro's (front) IDS/2, K&N, Jet Kit, racks removed (saved ten pounds). I also had problems with the rear tires rubbing . I removed the battery, and holder and slotted the bolt hole by one quarter inch. hav'nt had a problem with rubbing since (clearance is about 3/8" to 7/16". i used aluminum tubeing to support the headlight mounting area( from the top of the bumper to the front fender support. i flattened the ends of the tubeing and drilled mounting holes
any other ?
VLUCDOG
Old Feb 22, 2000 | 03:16 PM
Tim1's Avatar
Can't answer your question but I have one for you.My freind just bought a 300 Lacota its a 1995 I think and he would like to know how fast it will go. Its winter up here and he will not be riding it till the snows melts and has no puter to ask himself.
Old Feb 22, 2000 | 06:58 PM
vlucdog's Avatar
my best guess is about 50/52
VLUCDOG
Old Feb 23, 2000 | 11:25 PM
Sandman75's Avatar
Is there a kit to convert a lakota to manual clutch? any info would be great!
steve
Old Feb 24, 2000 | 01:13 AM
albert's Avatar
i have a mojave and i just installed dura blue wheel spacers on the rear. rode hard with them on last weekend. i was very pleased with how well they worked.
Old Feb 24, 2000 | 06:05 PM
98Lakota's Avatar
I have that conversion on mine. It was like that when i bought it. Still uses the factory plates with heavy duty springs. They just took the automatic clutch part out and added the lever inside the case to move the clutch from another bike; converted the rear hand brake to the clutch lever. It also has the parking brake removed.
Old Feb 24, 2000 | 09:16 PM
sl250r's Avatar
so what kind of manual clutch do you have and where did you get it how hard was it to install
thanks
