warrior pipe questions
is a fmf powercore iv2 and a powerbomb header better than a big gun complete system. is the fmf better than a wb. e series silecer (i want better as in complete power band) is any others pipes better than these. thanks for your help.
Suppertrap is ok but it restricts a lot of exhaust flow. I would Recomend the White Brothers Pro MEg. The head pipe is not nessesary because the stock warrior head pipe is very larg in diamiter. I have mine set up with the 12 disk and spark arestor. When i go to the track i remove all disk's, and put the end cap back on. I also jet up. This is very loud and provides more top end. When i go a ride at Colorado i stil the Quite core in with 10 disk and the spark arestor.
I've heard good things about the Big Gun Silencer also. But I wanted the best for my quad so I went with the White Bros. E-Series Pro-Meg. If you investigate things like I did for months you will probably come to the same conclusion. Good luck.
