warrior pipe questions
Old Feb 1, 2002 | 05:41 PM
warrior4969's Avatar
is a fmf powercore iv2 and a powerbomb header better than a big gun complete system. is the fmf better than a wb. e series silecer (i want better as in complete power band) is any others pipes better than these. thanks for your help.
Old Feb 2, 2002 | 07:03 PM
ridnwarrior's Avatar
You don't need a header pipe for a 01 Warrior unless you're running over 600 cc's from the thing. If you want what works the best look at my signature.
Old Feb 2, 2002 | 07:04 PM
That silencer is being run with 24 disks and the spark arrestor at 75 ft. above sea level.
Old Feb 2, 2002 | 08:06 PM
hey ridnwarrior if i dont need a header i should just get a wb e series. is there any other good pipes out there.
thanks for the help ill let you know if i get it
Old Feb 3, 2002 | 12:36 AM
ferd350CT's Avatar
Dont forget SUPERTRAPP....I love mine
Old Feb 3, 2002 | 01:07 AM
Blaster96's Avatar
Suppertrap is ok but it restricts a lot of exhaust flow. I would Recomend the White Brothers Pro MEg. The head pipe is not nessesary because the stock warrior head pipe is very larg in diamiter. I have mine set up with the 12 disk and spark arestor. When i go to the track i remove all disk's, and put the end cap back on. I also jet up. This is very loud and provides more top end. When i go a ride at Colorado i stil the Quite core in with 10 disk and the spark arestor.
Old Feb 4, 2002 | 12:06 AM
I've heard good things about the Big Gun Silencer also. But I wanted the best for my quad so I went with the White Bros. E-Series Pro-Meg. If you investigate things like I did for months you will probably come to the same conclusion. Good luck.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Backwoods_badass
Aug 27, 2015 11:23 PM
suzukiquadrunner1987
Aug 6, 2015 05:29 PM
Reactant
Jul 27, 2015 07:45 PM
