Raptor - Flashing Reverse Light
Old Feb 3, 2002 | 11:10 PM
BigJefe660's Avatar
On occasion when my bike is running in nuetral the reverse light will start flashing does anyone know what this means? Aside from the flashing light I haven't noticed any differences, but I'd like to know what it is telling me.
Cheers.
Jeff
Old Feb 5, 2002 | 12:52 AM
scottd's Avatar
Mine does the same thing. I'd also like to know!! Anyone? (my 2001 Raptor did not do this...only the 2002...so what changed between the 2 models?)
Old Feb 5, 2002 | 01:10 AM
the500bansheepilot's Avatar
your turn signal is on he he. Really though does the flash seem to have a pattern or does it just flash at random.
Old Feb 5, 2002 | 01:14 AM
scottd's Avatar
Mostly random, and when revving the engine in nuetral.
Old Feb 5, 2002 | 09:04 AM
MichaelAZ's Avatar
Ill cvheck mine as soon as the garage warms but Im thinking a safety issue so if you stop while duning "billybob the village idiot" wont run into you. [img]i/expressions/face-icon-small-shocked.gif[/img]
Old Feb 5, 2002 | 10:58 AM
garyc660R's Avatar
More than likely your problem stems from the switch located just above your rear brake lever. Your brake lever has a connector that runs to the switch, and the switch sticks. THis will make a lot more sense after you take a good look at the set-up. Simply lube this switch up. Worked for me.
Old Feb 5, 2002 | 12:53 PM
xgzx's Avatar
I posted about the same thing a while ago. No one knew what the problem was back then, either. I haven't figured it out, but it is the same situation as yours. Only does it while in neutral, revving or warming the engine. It is a steady blinking, not a random thing which would be associated with a loose connection. I have found that if you engage a gear it stops the blinking right away. However, putting it back in neutral and revving the engine will start the blinking again. I also had an '01 Raptor, it did not do this. I haven't found any ill effects from the blinking, but it is strange.
Old Feb 5, 2002 | 01:08 PM
2fiftyX's Avatar
I have also noticed this on my '02 raptor. It's not a random blink there is a pattern to it. It only does it in neutral, ideling or reving, I've seen it before, during and after a trip out. I'm not sure what it means but I figured it was like a check engine light and just wrote it off as maybe it's because it was colder out and running a little lean. not sure though?
Garyc660r maybe right also. But if it is a switch sticking wouldn't it just be a steady light and not blinking?
The truth is out there.
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
Derek Allen
Jul 22, 2015 09:25 PM
ltrmc02
Jul 22, 2015 04:50 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
