blaster front sprocket
The stock front sprocket has 13 tooth. I think that the largest you can get is a 14 tooth. A 14 tooth will give you a higher top speed (about 60mph) but will also remove alot of low-end (so it's wise to have a few mods that will improve your low-end)[img]i/expressions/face-icon-small-wink.gif[/img]. Hope this helped
I have a stock blaster with a 14 tooth front sproket. I did loose a little low end, it just took a little bit to get used. But I did gain 5mph on the top end. I have been clocked 3 seperate times at 65mph.. You just have to use the clutch a little more in the low-end.
As far as I know, 15+ tooth Blaster front sprockets don't exist. There are front 15 tooth front sprockets for Banshee's and other high HP ATV's, but I don't know if you can modify a Banshee front sprocket to fit a Blaster.
Whats the lowest rear sprocket size, whats the stock size, and how hard is it to install? Thanks
Frisky2050
Apr 9, 2020 11:19 AM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
joeyupton
Jul 14, 2015 11:51 AM
