blaster front sprocket
Old Feb 4, 2002 | 08:52 PM
tom18801's Avatar
what is the stock size front sprocket and what s the largest i can put on and how much more top speed will that give me
Old Feb 5, 2002 | 09:26 AM
DutchBlaster's Avatar
The stock front sprocket has 13 tooth. I think that the largest you can get is a 14 tooth. A 14 tooth will give you a higher top speed (about 60mph) but will also remove alot of low-end (so it's wise to have a few mods that will improve your low-end)[img]i/expressions/face-icon-small-wink.gif[/img]. Hope this helped
Old Feb 5, 2002 | 11:27 AM
blaster29's Avatar
I have a stock blaster with a 14 tooth front sproket. I did loose a little low end, it just took a little bit to get used. But I did gain 5mph on the top end. I have been clocked 3 seperate times at 65mph.. You just have to use the clutch a little more in the low-end.
Old Feb 5, 2002 | 06:33 PM
tom18801's Avatar
why cant i go larger will it hit that plastic cover has anyone modified that cover to fit a bigger sprocket
Old Feb 6, 2002 | 12:58 PM
As far as I know, 15+ tooth Blaster front sprockets don't exist. There are front 15 tooth front sprockets for Banshee's and other high HP ATV's, but I don't know if you can modify a Banshee front sprocket to fit a Blaster.
Old Feb 23, 2002 | 03:59 PM
YZBlaster250's Avatar
I have 14/42 gearing and it works great. Lots of low end but still has ton of to end.
Old Mar 10, 2002 | 11:06 PM
BansheeBoy2001's Avatar
Whats the lowest rear sprocket size, whats the stock size, and how hard is it to install? Thanks
Old Mar 11, 2002 | 01:47 AM
Blastermaster's Avatar
the 14 tooth will hit the plastic cover but i took my dremel tool cut away the top part in side, no problem
Bratman2
Aug 6, 2022 01:42 AM
Frisky2050
Apr 9, 2020 11:19 AM
drewy2dope
Ask the Editor
11
Jul 31, 2015 09:36 AM
95wolv
Jul 17, 2015 08:13 PM
joeyupton
Jul 14, 2015 11:51 AM
