trx 90 rear tires
I looked into tires when my son needed rears for his LT80, 19x7x8,I found the Kenda Scorpion at 20x7x8 was so close to stock, there was almost no difference. Look into some of the 20 inch tires,you will find a lot that are almost the same,if not shorter,than the factory. I even saw one guy running 20x11x8 holeshots on his kid's Honda 90, he said it gave great traction, and didn't seem to hurt the power,but they did seem a little wide. Anyway, check it out, you should be able to find something real close. Try Rocky Mountain ATV, or Tread depot, real cheap tires.
If you dont mind running a smaller tire on the back, try the 18-9.5-8 turf tamers with custom grooving. the grooving supposedly saves weight. We also bought some douglas aluminum rims too, but thats just because mine were beat up pretty bad. So far the tires have held up very well with a full year of racing and riding on them. they still have the dimples in the treads but i'll probably flip them around for this race season. I am very impressed with the tires compared to stock.
~BaTmAn~
'86 250r
LRD national motor/pipe/silencer & Hammer motor, AC pro pegs/bumper/grab bar, maier dark blue plastic, Nac's Racing graphic kit/seat cover/bar clamp/bar pad/brake block off/case guard/mud caps(beadlocks), marshall radial fronts on douglas .190's, holeshot mx's on douglas/champion beadlocks, Tag bars, leagers a-arms/swing arm, LSR axle, anti fade lock nut, Elka & PeP rear shock, Ekla front shocks, GS Racing wireharness/chassis bolt kit
'95 CR125r
'01 Raptor
'98 trx 90
~BaTmAn~
'86 250r
'95 CR125r
'01 Raptor
'98 trx 90
