How many parts from 300ex are interchangeable w/ 400ex frame?
Old Nov 14, 1999 | 02:46 PM
jbertch's Avatar
My local dealer has a 400ex frame at a very reasonable price, and I'm thinking I might buy it for my 300ex. I've done many engine mods, so the power is quite substantial compared to stock, however now I would like a better frame/chassis.
What I would like to know is if the engine would be a direct bolt in. And second, how many parts would be interchangeable from my 300ex with the 400ex frame. I am hoping I would be able to use the swingarm, a-arms, handlebars, axle, rear shock, etc...
The only areas where I think I may run into problems would be the exhaust, front shocks, and possibly gas tank. The exhaust probably would not mount up because of different mounting locations, so if I got an aftermarket exhaust for the 400ex, would it connect to the stock 300ex head pipe? Also, the front shocks on a 400ex are longer than the 300ex, correct?
Any help and insights would be appreciated. I'm hoping by upgrading to the 400ex frame, over time as my budget allows, I would be able to upgrade to higher performance chassis accessories compared to what is currently available for the 300ex.
Thanks in advance.
Old Nov 15, 1999 | 12:07 PM
dtalbott's Avatar
My advice, for what it is worth, is to get 400EX a-arms and shocks if you get the frame. They are cheap enough ( 220.85 for a-arms and shocks 129.00). You could run 300EX shocks, but you will have to lower the mounts about 3 inches. You can run 400EX a-arms on a 300EX with 400EX shocks with a shock relocation kit from ATV Racing.
The 400EX fuel tank is also cheap (66.95).
The swingarms measure the same width, but I don't know if they can be swapped. Also, difference in length of rear shock.
Hope this was at least a little bit helpful.
See Ya,
Darrin Talbott
Old Nov 16, 1999 | 05:41 PM
JSR9900's Avatar
I was reading this and I have a question..... Does the 400EX swingarm fit the 300EX chassis?
Reactant
Mar 30, 2022 02:08 AM
lightninboy
May 16, 2021 09:52 PM
metal249
Jul 24, 2015 01:00 PM
95wolv
Jul 21, 2015 12:25 PM
yambam13
Jul 4, 2015 01:49 PM
