Bigger Rear Tires
Old Feb 13, 2002 | 06:47 PM
s1ane's Avatar
Will this make my TRX300 go faster or slower?
steve
Old Feb 17, 2002 | 10:04 PM
Hondasaurus's Avatar
Faster, but at a cost. It will seem like the atv has less power.
Old Feb 19, 2002 | 01:17 AM
54warrior's Avatar
I'm sorry, but I have to disagree with you Hondasaurus. Increasing the tire rear tire size will decrease speed, and will increase torque. This is a result of the larger diameter of the tire. The engine will still be turning the sprocket at the same speed, but the circumfrence of the tire is larger, therefore decreasing speed. It works the same was a changing the size of the rear sprocket does. Larger=slower, more torgue. Smaller=Faster, less torque.
Old Feb 19, 2002 | 02:33 PM
DTRAIN's Avatar
The bigger the rear tire the faster you will go, but the less torque you will have. This is 100% true. You can compensate for this by changing your sprocket. Remember, you will be faster (top end) but it will take you longer to get up to speed.
Old Feb 19, 2002 | 07:41 PM
kukerdan's Avatar
yup, more speed, less torque
Old Feb 20, 2002 | 11:30 PM
54warrior's Avatar
yeah, my bad...was having a bad day, couldn't think straight. sorry for messing with your head.
Old Mar 11, 2002 | 10:45 PM
dcroc's Avatar
If you go with larger dia. tires on the rear watch the brakes, tends to increase front wheel lock up on some models. Hope this helps.
Bratman2
Aug 6, 2022 01:42 AM
STLyamwar
Jul 25, 2020 04:44 AM
Jul 24, 2015 11:57 AM
rcappie4
Jul 18, 2015 07:51 AM
rcappie4
Jul 10, 2015 04:54 PM
