Bigger Rear Tires
I'm sorry, but I have to disagree with you Hondasaurus. Increasing the tire rear tire size will decrease speed, and will increase torque. This is a result of the larger diameter of the tire. The engine will still be turning the sprocket at the same speed, but the circumfrence of the tire is larger, therefore decreasing speed. It works the same was a changing the size of the rear sprocket does. Larger=slower, more torgue. Smaller=Faster, less torque.
The bigger the rear tire the faster you will go, but the less torque you will have. This is 100% true. You can compensate for this by changing your sprocket. Remember, you will be faster (top end) but it will take you longer to get up to speed.
Jul 24, 2015 11:57 AM
