grease fittins
Old Feb 14, 2002 | 01:38 AM
raktrakr's Avatar
would it be possible(or wise) to drill and tap the front bushings on my grizz for grease fittins
Old Feb 14, 2002 | 06:41 PM
54warrior's Avatar
not sure if it will work or not, as i am unfamiliar with this machine, but it definately couldn't hurt.
maybe if you were a bit more specific: a-arm bushings? or something in the 4wd?
if it's the a-arm bushings, just make sure that they won't interfere with the mounts in any way... because when the suspension is fully compressed, they might hit part of the frame and snap right off.
Old Feb 14, 2002 | 10:03 PM
raktrakr's Avatar
a-arm bushings,dont know why i didnt say
Old Feb 24, 2002 | 09:53 AM
tom18801's Avatar
it can be done you would have to take the bushings out though and put a grease groove in them about a 45 degree angle all the way around
Old Feb 24, 2002 | 12:46 PM
crazyhorse03's Avatar
actually all you have to do is drill the right size hole in the center of the other tube at the end of the a-arm tap it then just screw it in. ive done this with three different quads that i have had and its always worked fine
bigred20653
Sep 19, 2015 02:11 PM
bmark0610
Sep 7, 2015 09:42 PM
rawbdiggity
Sep 7, 2015 12:05 PM
toonces
Aug 5, 2015 05:55 PM
toonces
Jul 28, 2015 01:58 PM
