beartracker help
Old Feb 18, 2000 | 06:52 PM
wolverine_4x4's Avatar
i have a 99 beartracker and ever since i got a flat about 3 months ago i started to hear noises where my back brakes connect to the tire when i drive slow? what could it be
p.s i rode the flat about half a mile on pavement
Old Feb 22, 2000 | 09:12 PM
yam's Avatar
yam
My beartracker did the same thing I couldn't figure it out but when I had my warranty replace the rear end (I dont think the rear end is why) I told them to clean my brakes, I don't know if they did do it though , but there isnt a squeek anymore. My guess is there was dust, dry mud, or hard water in the brakes. So try cleaning them and see if that works. good luck cleanin em cause I can't figure out how to take them apart myself.
Old Feb 23, 2000 | 04:32 PM
gwizardzachatv's Avatar
your going to have a lot of brake problems because you have drum brakes. disk brakes is the way to go but anyway you will have to run a high pressured water hose in your drum brakes everytime you ride it or you will have to change your brakes every month of more and it is not cheap i own a bearktracker just like you if you keep your brakes clean and fresh then you wont have to change them that much
Old Feb 24, 2000 | 10:47 AM
95TimberWolf's Avatar
ya you will have alot of problems with drum brakes. i have the same problem that your having all of the time and it is mud in your brakes. get you a repair manual and it should tell you how to take your brakes apart.
HunterExplorer
Mar 5, 2002 06:43 PM
doggster
Sep 3, 2001 12:43 PM
beartracker14
Mar 23, 2001 12:03 AM
Rebel
Aug 26, 1999 12:11 PM
