No More Flat Tires?!?!
Old Nov 15, 1999 | 09:35 PM
gohl's Avatar
1. Has anyone used these liquid fix a flat products for atv's. I'm sure the answer is yes)
2. What are the disadvantages?
3. Will this stuff ever stop working?
4. Will it freeze a tire out of round
when cold?
5. What happens when you take the tire off
the rim?
6. What brand do you recommend?
Old Nov 15, 1999 | 11:01 PM
JRM's Avatar
JRM
I use slime.. it seals pencil size holes perfeclty.. I never can tell it is there either, no out of balence probs
Old Nov 15, 1999 | 11:04 PM
rooster's Avatar
Gohl, I've seen the liquid fix a flat stuff, and it doesn't work to well. I'm not sure if it allows the tire to hold air forever, but they will screw up the valve stem pretty easily.
I've had very good luck with "Slime," that green colored stuff. I've never had a tire that failed to hold air after it went flat and I put slime in it, and I've done at least 5 or 6 tires already, it even sealed a leak at the beads of the tire! Recently our Sportsman 500 had a flat tire in the front, no, we didn't bring it in and get a patch, we just put slime in it, never leaked air since! The stuff works great, plus it stays in the tire forever, and if you pick up a nail or something again in that tire, it will seal it again, cause it remains a liquid in the tire. It doesn't unbalance the tire, and it is pretty easy to put in. I highly recommend this stuff, plus you don't have to worry abou tthe tire shop scratching or chipping the paint off of your rims when they take your tire off or put it back on.
[This message has been edited by rooster (edited 11-15-1999).]
Old Nov 16, 1999 | 08:12 AM
atving's Avatar
on using the slime how much do you put in each tire do you put a whole bottle or what, I am interested in getting some...thanks
Artic Cat...no fun with a flat
Old Nov 16, 1999 | 03:26 PM
rooster's Avatar
An ATV tire requires 16 ounces, bicycle and motorcycle tire 8 ounces. They come in bottles of 8oz., 16oz., 32oz., or a bucket. They also come with everything required to put it in, (tube and valve stem remover) just not the air to pump the tire.
Old Nov 16, 1999 | 09:52 PM
BONER's Avatar
I have slime in my left front tire. I have noticed that if you take off, after your quad has sat for an hour or more, fast (40+) it is very unbalanced for about 200 yards but it balances it self out after that. If you ride around for about a 1/2 mile before going 40+mph then you can't tell that the slime is in there.
Arctic Cat 500, Pizza, Pizza!!!!!!
Old Nov 17, 1999 | 01:30 PM
TDS's Avatar
TDS
Does anyone know if slime freezes when the weather gets cold. That would probally cause big balancing problems.
Old Nov 17, 1999 | 08:05 PM
rooster's Avatar
TDS, slime does not freeze in cold weather.
Old Nov 19, 1999 | 01:51 AM
spanknquad's Avatar
I've used slime in my 3-wheelertires and it actually sealed an inch split.It's very reliable stuff.
2quiker
Mar 22, 2022 08:36 PM
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
caveeagle
Sep 19, 2015 01:20 PM
essonlaker
Sep 10, 2015 01:12 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
