Front tires on my 500 HO
Old Feb 27, 2002 | 05:08 PM
kodiakkid's Avatar
I want to put a bigger, meatier tire on the front of my SP500 .I want to just leave the back tires at 25 11 10 And put a wider and maybe taller tire on the front.What can i use????
Thanks, JOHN
2002 YELLOW 500 HO
Old Feb 27, 2002 | 06:04 PM
500DUSE's Avatar
I dont think you can go taller in the front without doing the back(it'll mess up your diff or something)
Old Feb 27, 2002 | 06:38 PM
kodiakkid's Avatar
So what would a good size be if i just go wider?
Old Feb 27, 2002 | 08:14 PM
500DUSE's Avatar
25-10-12's(front) and 25-12-12's(back) would be good.
I like the ITP's 589's m/s
but there's other good one's also.....titans...muddrunners
Old Feb 27, 2002 | 08:44 PM
showmethemud's Avatar
I'm assuming your are staying with your stock rims? If you are, the widest you could use would be a 9 in. wide tire. I have 26x9x12 on stock front rims and the tire is pretty close to rubbing the tie rod end on the right side(actually had to use a small spacer to keep from rubbing it). I think the 25x10x12's may be a bit too wide for the stock rims.
Old Mar 3, 2002 | 09:37 PM
mtpockets's Avatar
KodiakKid,
i have a set of Outlaws F+B and they rub like hell on the front- even with spacers.
my advice: if you plan on going wider up front, budget for new progressives or HD springs. you'll need them!
later,
MT
Reactant
Mar 30, 2022 02:08 AM
baysport
Jul 23, 2015 11:37 AM
rcappie4
Jul 18, 2015 07:51 AM
JackTheKing
Jul 14, 2015 09:09 PM
tporath
Jul 11, 2015 12:31 PM
