Mohave Clutch question
Old Mar 8, 2002 | 12:30 AM
dtssr's Avatar
Just tore down a 1990 Mohave to replace idler gears for kick start. Had to do complete teardown to replace reverse gear shaft that bad idler rounded down. Now, after putting it all back together, I have a concern. The clutch housing, and shaft it's on, has about 1/8 inch of movement back and forth. That is you can pull on the pin or housing and the whole assembly will easily move outward, then inward about 1/8 inch. Since I took it apart a month ago, waited for parts so long, I can't remember if that's normal. The gears on the back of the housing mesh OK despite the movement. Turning over by hand, shifting thru the gears, all seems to be fine.
I hate to have to tear this down again to check only to find out it's normal.
I also would hate to hear the motor grind to a halt first time it's started. Anyone have any input? Thanks.
Old Mar 8, 2002 | 08:58 PM
mentalmojave's Avatar
My 01 mojave does the same thing. I wouldn't worry about it. I only have a summers worth of mileage so its not like its wore out. I noticed mine when I installed a barnett clutch and springs.
Old Mar 10, 2002 | 02:29 AM
mojaveman1's Avatar
how much was the barnet clutch did it help and where do you get it
Old Mar 10, 2002 | 12:04 PM
The barnett kit cost me 110.00 through Jl Atv products. It seems to have a much more positive feel than the stocker but I'll tell you more when all the snow melts.
Old Mar 12, 2002 | 02:52 PM
dtssr's Avatar
Thanks. That was normal.
All went well, cept' for a stripped clyinder head cover bolt slot. The others aren't enough to hold cover down tight, oil blows out agound gasket there. We'll try a longer bolt to see if we can catch some new threads.
The boy posted some pic of the re-build process at his web page:
www.dtssr.com\quadzilla
ghost civic
Jan 15, 2020 07:43 AM
4464
Aug 21, 2015 01:46 AM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
